Ga door naar hoofdinhoud
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Vragen Bekijk alle
DVD Drive not working on iMac 21"
I started hearing my dvd drive trying to eject but there is no disk so I tried running off of dvd on startup but no it now can't read the drive the disk dosent even comeup I was trying to run disk utility but it cant repair unless it off startup disk!!
So I tried target mode and repaired it off another computer said it repaired it but no still not working !! I can hear the drive working, Im a Mac guy since day one of mac's.
I dont know what to do Next?
Help
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
I've never had much luck repairing optical drives. Sometimes a lens cleaning disk will work. Here's how to replace the drive: iMac Intel 21.5" EMC 2308 Optical Drive Replacement
Or just get an external that will move to your next machine. I like the LaCie USB/Firewire combo drives: http://www.lacie.com/us/products/range.h...
Was dit antwoord nuttig?
Score 1
If you are under warranty, just have Apple replace it with a new one. If you are out of warranty, try the cleaning disc as @mayer suggested.
If for some reason that doesn't work, replace the optical drive.
Score 1
1 Opmerking:
+ agreed
door
Het nuttigste antwoord
I got new dvd drive when it stop working , have you check whit Apple : I think it was something wrong whit some of the dvd drive on the marked . It take a cd but can not read ore writ . It can work one some cd but not one adders ,like install CD . May English is bad but i tray to say that in some cases they give you new drive and install it for you .
Score 1
Wow that s a great answer but its not under warranty :) hmm
Voeg je antwoord toe
Marc Lappano zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 8,642
