Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
3038 Vragen Bekijk alle
Why wont my screen turn on
my screen wont turn on. my phone is still active, it respones, so like when i hold down the home button siri will talk to me but nothings on the screen, and when i plug it into the wall it makes the sound but doesnt come up on the screen, my screens pitch black and wont turn on
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
SLA DE UPGRADE OVER
Bespaar door het te repareren met een alles-in-één kit.
Shop iPhone Fix Kits
SLA DE UPGRADE OVER
1 Antwoord
The panel connector inside the phone could have possibly come dislodged. To check for this, remove the two pentalobe screws on the bottom of the phone and push the back of the phone up and lift the back glass off. Check each connector pushing onto each one to make sure its snug in its slot. Then slide the back casing back on and re-screw in the pentalobe screws. Turn the phone back on and if the screen is still unresponsive I would suggest replacing the display which you can buy directly from us, and we have a guide on how to replace it as well. Feel free to PM me if you have any questions on purchasing or using our guides!
Was dit antwoord nuttig?
Voeg je antwoord toe
emma Gold zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 78
