Ga door naar hoofdinhoud
The Sanyo VPC-X1200 is a 12.1 MP point-and-shoot style digital camera.
7 Vragen Bekijk alle
How do I get my videos from sanyo
how do i get my videos from sanyo
Is dit een goede vraag?
1 Opmerking
Dsean Henry Sanyo what? What have you tried? what computer do you have? What software are you using?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Usually cameras have a slot where you open it up and remove the SD Card, where all photos and videos are stored. Some require you to push in and it will then eject.
Then you would connect the SD card to a PC either directly (Some have card slots) or use a USB to SD Card adapter.
Was dit antwoord nuttig?
Score 2
Usually you can get them on a computer if you use a cord that has a "B" on one end and regular usb connection on the other. The computer will pick up that the camera is attached and will install drivers (depending on type of computer) to give you access to the camera's internal memory. If you have a card installed, you can remove that card and insert it to the computer using a card reader unless the computer has one installed on it.
From there you should be able to just click on the cards folder and get your pics.
Score 1
Voeg je antwoord toe
Dsean Henry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 173
