Ga door naar hoofdinhoud
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
ipad 3 stuck on apple logo
hi, i have an ipad 3, when i turn it on, it stucks on apple logo for a while and then it turns off, i have used another battery also but still problem is not solving, plz help
Is dit een goede vraag?
Score 3
3 opmerkingen
1. Turn off or restart your device. If you can’t turn it off, press and hold the Sleep/Wake and Home buttons at the same time and wait a few seconds for it to turn off.
Plug the device’s USB cable into your computer only.
Hold down the device’s Home button as you connect the USB cable to it.
When you see the Connect to iTunes screen, release the Home button. If you don’t see this screen, try steps 1 through 3 one more time.
2. Use RecoveryTool Fix Recovery to solve this problem easily.
door
Successful for me on my son's old iPad3. The iFixit folks know what they're doing!
door
worked for me,thank you!
door
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
The most likely problem here is a poor connection between the battery and the logic board, or bad new battery. The behavior you're describing is how an iPad 3 responds when it is not well seated on the battery.
iFixit Staff Edit: For more details on how to diagnose boot issues with an iPad check out our iPad Stuck on Apple Logo troubleshooting page. It contains more information on why this sort of behavior occurs and further steps to fix this issue!
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
i have tested it with external power supply also,but still same problem
door
hi, i followed your advise and checked logic board in another housing with known good battery and it worked, thank you so much jessa, i have learnt so much from your youtube videos.
once again thanks
door
awesome--great job :)
door
It seems like your iPad is stuck in a boot loop. This is due to corrupted files on the actual device, and not so much to do with the power. Try to pull your data off of the device using iTunes, then do a full restore of the device. This will take a while, because it will be downloading the software from Apple's servers and installing it on your iPad. You may want to set this as an overnight task. Hope this helps.
Score 1
1 Opmerking:
itunes is not recognizing it
door
Time for a trip to the Genius Bar! If iTunes is not recognizing the device, then you're going to need some higher level help. Make an appointment and take it to the Genius Bar for diagnostics. Meanwhile, you can reinstall the various connectors that you may have to had removed in order to do maintenance, to see if an improper connection could have led to the failure of the built in start up test. (Most Apple devices will run a hardware test before booting the operating system, and if it fails this test, then iOS will not boot.) Hope this helps!
4 opmerkingen:
What? This is even worse than the zif connector advice! The Genius Bar has no ability to help with hardware defects!
door
The genius bar can replace or repair your device with the proper permissions from the device's owner.
door
The out of warranty replacement cost for an iPad 3 at Apple is $299--assuming that they would even take it since it has aftermarket parts in it now.
The price of an excellent condition iPad 3 on eBay is about $174.
A trip to the Genius bar for this problem is a total waste of time.
door
Brought my iPad 3rd Gen (Model No.1416, 32GB) to the Apple Store in Manila to see if they could fix the problem, described as follows: 1. Unit went to sleep and won't wake up anymore. 2. With charger attached and plugged in, battery charge icon blinks for a few seconds then goes out. 3. Apple logo finally managed to appear after several charging tries, but that was it. 4. Screen now alternates between Apple logo and battery charge icon (with the red indicator bar staying at the lowermost position), then goes black. 5. My Macbook Pro doesn't read the iPad when attached.
After keeping the unit plugged for 30 mins and confirming the problem, the store recommended getting a new unit without doing any diagnostics. Simple answer to me: "Repair not recommended. Get a new one." Sucks.
Will battery replacement fix the problem?
door
My iPad stuck on the Apple logo screen, and reboot is useless. At the beginning, I follow the support from Apple. https://support.apple.com/en-us/HT201412
But I think it don't work well. So I google some recovery tools, and find the FonePaw iPhone Data Recovery is OK. It can solve the stuck by one key, and quickly to recover. It also can recover data from iPad
Hi, where do I find the Recovery Tool?
Voeg je antwoord toe
manubali811 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 50
Altijd: 8,536
