Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
Is the display glass on an iPhone 6s Compatible with iPhone 6?
Can the display glass for an iPhone 6s be replaced with the display glass for an iPhone 6? Are they compatible? Mine is less than a week old and already cracked.
Is dit een goede vraag?
Score 2
1 Opmerking
Always take it to Apple. Warranty or not they will fix broken screens for $100. You never know what type of LCD you're going to get on eBay or sham "we fix phone" shops.
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Well first off, you can't actually just replace the display glass on the newer iPhones. They've got a fused display, so you'll have to replace the whole thing. (unless you've got some specialized tools)
As for using a 6 screen on a 6s screen, I know for a fact there are dimensional differences, and the fact the new screens have the extra 3D Touch layer, which you'd be missing by using a 6 screen. I can pretty definitively say this wouldn't work well if at all.
So you've got a couple options, you can wait for replacements to start being sold (actually there are some for sale on eBay but they are very expensive, like 400 bucks+) or you can go through Apple. In your case, this might actually currently be the cheaper option. You've still got your 1 year manufacturer warranty, so that would reduce the cost of the service right off the bat. If you picked up Apple Care you can use that as well.
Was dit antwoord nuttig?
Score 4
not compatible, the screen clip is diffrent to begin with and many more differences
Score 3
1 Opmerking:
many differences? Such as? I though iP6S glass is about 3 mm bigger than iP6 glass.
door
It is compatible because I just did it on my sister's iPhone (I accidentally ordered the wrong screen and only noticed it when i went to check the 3d touch and it wasn't available.)
I wouldn't recommend it as the iPhone 6s screen and digitizer is $70 more than the 6.
1 Opmerking:
How did you do it? Aren't the connections different?
door
na my yg don't work fam
Voeg je antwoord toe
Klaus1Eleven zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 27,128
