Ga door naar hoofdinhoud
This is the first generation of Amazon Fire TV (model CL1130), released on April 2, 2014. It is a powerful media streaming and gaming device that allows the user to stream digital audio/video content to a high-definition television as well as play video games.
Why can’t I get internet access with a wired Ethernet cable?
When I try to connect to the internet using a wired Ethernet cable connection, the Amazon Fire TV will act as if there is no internet connection. What can I do to fix this problem?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
There could be a couple reasons for the Internet connectivity problems. Maybe the Ethernet cable is not correctly connected, or the router is not providing Internet access. Maybe it's also a hardware problem, in which the Ethernet input port may be damaged. For more information, visit
Amazon Fire TV Troubleshooting
Was dit antwoord nuttig?
3 opmerkingen:
useless information. how is this solved ?
door
I use the Amazon Cube 2nd Gen. When I connect ethernet Have to cut off Wi-Fi The problem that I have I cannot use my Amazon echo's Because when I cut off the Wi-Fi on Amazon cube It disable everything else So I have to use either or
door
Hasn't solved my problem must be problem with new fire stick
door
Why won't my internet is not working what is going I have xfined
Voeg je antwoord toe
cory burke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 14,558
