Ga door naar hoofdinhoud
The first generation of the executive car by Volvo known as the S80.
10 Vragen Bekijk alle
makes a loud "BRRRRRRRing" sound when trying to start & doesn't start
Battery dead. Hooked up to charger. Try to start and a LOUD BRRRRRRR or Clucking sound comes from under the hood. Car will not start.
Put a charger on the thingy under the hood to jump start but didn't work. Battery itself is in the trunk. Should I have put the charger there instead?
Is dit een goede vraag?
1 Opmerking
Thank you all soooo much. It has made what seemed to be a weird problem, much easier to understand and to not be so worried about some massive expense to fix it. Being uneducated about cars is worse for me, being female, because I seem to be at the mercy of too many mechanics. With your help, I've solved the problem with only the expense of a new battery. With Gratitude. Sharon
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Sharon not quite sure about the noise, but from what you are describing it is the starter solenoid making that noise. Recharge you battery and have it checked to see if it holds a charge. If a new battery does not fix that, check the starter itself. You can try to "hotwire" it to see if it works, most likely you will need to replace it.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
thank you! it is now all fixed. new battery took care of problem!!
door
This noise is what is made when a weak battery does not have enough power to engage the starter gear far enough to mesh in the flex plate/ring gear/flywheel.
door
Has it been sitting there for a while? If it tries to turn over, then the battery is fine. When was the last time you replaced your plugs and wires? It seems like its the actual starter or some component thereof rather than the battery. Hope this helps
Score 1
2 opmerkingen:
thank you. yes, it had been sitting a very long time. i tried to charge the battery with a trickle charger and it did try to start but kept making that crazy sound. a new battery cured it. sharon
door
Glad to hear it. :) Happy halloween!
door
Voeg je antwoord toe
Sharon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 371
