Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Vragen Bekijk alle
Can I upgrade my MBP Mid 2010 with Samsung 850 Pro SSD
Hello,
My 500gb HDD just failed on me so I am taking the opportunity to smack in an SSD into my Mid 2010 MBP and do a clean install of the OS. Does the Samsung 850 Pro(512GB) compatible with my MBP? Anyone out there with the same MBP model upgraded theirs with the 850 Pro? Any other brands/model that I can look in to if its not compatible?
Additional information:
  • Macbook Pro 6,2 (Mid 2010)
  • Intel core i7 2.66GHz
  • 8GB Ram
  • NVidia Geforce 330M
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
To start with you'll need to follow this IFIXIT guide: MacBook Pro 15" Unibody Mid 2010 Hard Drive Replacement to replace your current drive with a SSD.
As to who's SSD: We have mostly been using Samsung's EVO SSD's We don't use the Pro version. While many claim the Pro's speed and longer warranty is better. In the real world the EVO will serve you just as well at a lower cost. Here's a good write up: Samsung 850 PRO 2TB SSD Vs Samsung 850 EVO 2TB SSD while they are biased to the Pro, our user's experience over two plus years of use suggest the EVO was just fine.
The only thing here I do strongly recommend is you run the latest version of Yosemite (10.10.4 or newer) as it has TRIM services natively. You'll need to follow this: How to enable TRIM on third-party SSDs in OS X.
You'll want to get a large enough drive so 1/4 to 1/3 of it is kept free once you install all of your stuff. If you are finding the price of the SSD is getting too high for the size you need you may want to think about a SSHD drive like Seagate's or a dual drive like Western Digitals Black2 drive instead.
Don't forget to make sure your systems firmware is up to date before you start. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers
So the bottom line here is: The water is just fine which ever SSD you go with ;-}
Was dit antwoord nuttig?
Score 9
7 opmerkingen:
Update: Western Digital is no longer selling the Black2 drive.
door
Yes. Working very well on my MBP mid 2010, i7 2.66, 8 GB RAM.
regards
door
Hi, I can confirm it works just fine. No idea on Evo vs. Pro, I just got a good deal on the Pro and got a 512Gb version. Have it for 6 months in my mid 2010 15" and it's lovely.
door
Will it work for the 13" model 2010 MBP 2.66ghz?
door
Mark - The Samsung 850 series (EVO & Pro) have been replaced with a newer 860 series Samsung 2.5" 860 EVO
There is very little difference between the 850 & 860 other than the flash chip architecture. Both used the same Samsung Controller logic and both will work in any MacBook Pro which supports a 2.5" SATA drive.
door
2 commentaren meer tonen
Hello I’m about to order the newer samsung 860 evo for a macbook mid 2010, I guess it will do just as well as the 850?
Score 1
3 opmerkingen:
Yes! You'll be fine. I do recommend you replace the HD SATA cable with a newer version as these tend to fail after awhile.
door
@danj I was fine and then the cable failed as you predicted :P
I should have changed it back then with the HDD but no harm done anyway.
door
I bet your heart missed a beat or two when it happened ;-}
door
Voeg je antwoord toe
rdknp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 37,349
