Why does my phone say invalid battery and not charging
droid x battery not charging and has question mark inside battery icon
Is dit een goede vraag?
Zccsalter, could be caused by a bad battery. Consider changing it. Try to remove the battery and keep it out for while then reinsert and see if that helps. You could also try a hard reset (carefully because you may lose your files). It may be because the battery is discharged beyond its threshold and does not take a charge. Once that happens, your phone does not get the right information (proper voltage is part of the signature information) from the (smart battery)it declares it as "invalid" and will not charge it. For that you could try to charge the battery on an aftermarket charger outside the phone for a few hours.
Was dit antwoord nuttig?
sorry it doesn't work for me. I bought my phone few days ago. when its battery under 15% phone automatically turn off & then show invalid battery when i want to switch on my phone.
Is there any software problem or something else?
This is a replacement battery I bought that is doing this. I did request from the seller to send me another because this one was indicating invalid battery and the second one says the same thing. Both batteries came at a 50% charge on them. I do not have an aftermarket charger for this kind of battery. What ti do then?
This is the old phone, but I have a I that’s from the company but it still says a valid battery battery
What should I do about it?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 14,812
