Ga door naar hoofdinhoud
Repair guides and support for the Leapster L-Max, a hand held learning game system for children ages 4+, developed and released in 2005 by LeapFrog.
How do I get the battery to charge?
I cannot get the battery to recharge. The green light flashes while charging for more than 8 hrs. Battery still not charged. I have cleaned the terminals as recommended by the company, but no luck.
I am willing to buy a new battery if I could just find one.
Is dit een goede vraag?
Score 3
1 Opmerking
Mine has batteries in it but isn't charger not even turning on what do I do is there anyway to reset it?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
i searched ebay a little bit and found a battery cover/holder.
i don't know whats normally in the leapster l-max - but this holder looks like a 4 x aa battery holder: CLICK
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Hi.
1. you can buy a wall charger (charge the battery connected to the wall socket) and connect to the ipod.
2. electro Shocks to your battery. You can use a power supply of 5V (for example an AC adapter with this power) and connect with a terminals to the pads of the battery this only has to be for a seconds, otherwise the battery will be burn.
after this process you can chek your battery with a multimeter
You plug in the charger to the wall, and then put it into your leapster device.
Voeg je antwoord toe
Ruth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 39
Altijd: 6,063
