Ga door naar hoofdinhoud
Repair Guides for Dell Desktops.
446 Vragen Bekijk alle
Vraag afgerond
Need drives download back on computer
How to download drives for windows XP please
Dell windows xp
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
You did not supply your model number so I can not give you a direct link to driver downloads for your model. To obtain drivers it is always best to download them from the manufacturer of your PC. So you should be able to go to Dell's website and obtain the drivers for your specific model. Most of the time the driver downloads can be found in the support section of the website. Here they ask you to enter you model number and then you should be able to locate and download XP drivers for you hardware. If you need more assistance locating the drivers than reply back with your model number and I can supply links to driver downloads.
Was dit antwoord nuttig?
Score 1
Generally, after installing system, some drivers for devices will be installed at the same time. If you find some devices can't work caused by driver missing, you can fastly download and install drivers for Windows XP with driver manager program.
You could use windows drivers update utility to help you. It is suggested Driver Talent to you. It is rich-featured, which is able to scan to detect your drivers, verify the problem drivers, and fix the problem for you. Definitely, it could also help to download and install the latest windows drivers.
I ever lost a driver from my Asus laptop. However, I used a tool to manage drivers in my computer including Windows drivers backup, finally, I restored it backup.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 93
