Ga door naar hoofdinhoud
These white headphones are equipped with a remote and mic, and come with Apple's music players and iPhone. They are also sold separately. Released on September 9, 2008.
6 Vragen Bekijk alle
Can the remote on these headphones be repaired?
I just recently purchased Apple's in-ear headphones. Not the ones pictured here, but the ones with the rubber noise canceling buds. I wore them in the rain the other day and now the microphone isnt working and the volume + and - buttons are not working. Oddly enough, the Play-Pause center button works just fine. Being that these are pretty expensive and cannot be returned due to my negligence, I wanted to know if this tiny remote can be opened and cleaned up?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
that doesn't sound good (no, thats not a lame joke - lol)
i never had those fancy headphones - can you see any "seam" ?
if there is something to open them - get some isopropyl alcohol (>90%) and a paintbrush (i know you like them much) and clean the contacts & switches.
but since it's an apple product, it would not be that easy to fix, maybe they casted/sealed/glued the thing a few times together.
but there might be another thing - get the "old" ones from ebay - they are cheap (and most likely fakes) - remove the earbuds from the cheap ones and place your in-ear pieces on it.
it would be still a tough job but way cheaper than a pair of (still chinese) headphones for 80 bucks
good luck
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Thanks Markus. The remote has a seam, but like you said, it might be sealed so if I try to pry them open the remote might completely break..I'll give it a try. I will keep you posted.
door
Ahhhhh, I finally get to use the paintbrush and alcohol combo. LOL
door
i knew it ;-)
door
can u describe how u fixed it? i have the same problem. i took them out on my bike, it started raining, now the sound works but the play/pause and volume buttons don't work.
Neerav
Voeg je antwoord toe
Majesty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 7
Altijd: 6,597
