Ga door naar hoofdinhoud
PowerBook G4 Aluminum laptops with 12-inch displays. Released in 2003 from Apple.
How do I take out this screw?
Hi!
I've followed iFixit's guide on how to disassemble my PowerBook 12 to get to the logic board. So far, I've removed the keyboard and all other screws, but there is one piece left. It almost looks a like a small rivet, just with a hole in its center. It also has small fins/turbine wings on its outer circle.
Is there any tool to remove such a "screw"?
I appreciate any help - thank you in advance!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
ddybing, that is not a screw. That is a standoff and it does stay.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Okay - that's a bummer, as it seems to keep me from removing the upper case.
Thank you for your quick answer :-)
door
Where does it seem to be sticking?
door
I tried a few more times, and then it loosened. It seemed to stick on this "rivet".
So it's all fixed now. Thank you for your answers!
door
Voeg je antwoord toe
ddybing zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 119
