Ga door naar hoofdinhoud
The Asus Padfone 2 was announced on October 16 2012 and is the successor to the Asus Padfone.
16 Vragen Bekijk alle
How can I unfreeze my tablet
My tablet is frozen what can I do
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
tresastephens, I am sure that you already tried to remove the battery for a short time and then reinsert it. Also, try a soft reset by pressing and holding the power button for +10sec. After that you can try a hard reset. This will delete all your files. Press and hold volume Down button and power on the phone.This should get you in recovery mode. Here you can select to do a factory reset by using the Volume Down key on the menu.
Was dit antwoord nuttig?
Score 2
Press and hold volume up and down and power button at the same time will take you to safe mode power off wait two minutes power on.
Voeg je antwoord toe
tresastephens zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 3,435
