Ga door naar hoofdinhoud
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
20 Vragen Bekijk alle
How to "fix" broken keyboard backlight ribbon cable port?
I have a macbook pro mid 2010, 2.4 GHz A1278 model and I recently opened it to clean because of a liquid spill. Luckily the liquid did not go in deeply that after I cleaned the inside parts it's working perfectly except for the keyboard backlight stopped working. Pressing keys F5 and F6 shows the backlight level on the screen but nothing really happens. And i realised that the keyboard backlight ribbon cable port, on the logic board, is broken( only the tiny clipper part that locks the cable).
My question is is there any simpler way to fix this other than replacing the logic board for the backlight to work? Any suggestion would be appreciated.
Update (09/04/2015)
Hi Sterling,
here is the actual picture of the part that's missing, Its the small plastic part that holds the keyboard backlight cable in place. difficult to get a good resolution picture with a ordinary camera but i tried my best.
Is dit een goede vraag?
Score 3
1 Opmerking
Can you post a photo of the broken clip?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Is it possible to push a little bit and just wedge the cable in there? I didn't remember there being a clip there, but I may be wrong. Is it possible the backlight itself was damaged in the spill?
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
is there a part number for this clip? I have the same issue and it seems the clip is missing off the ribbon
door
I also have this problem. Does anybody have an answer?
door
Voeg je antwoord toe
Henock Girmachew Mullissa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 1,988
