Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Sony Xperia Z3 Compact uitgebracht in september 2014.
How to replace the microphone?
My Z3C has been dropped. The rear cover has cracked (looks like a relatively easy job with a bit of time and care) but also the microphone is not working properly. The person on the other end of a call can bearly hear.
Looking through the strip-down, the microphone is not mentioned, but there is an obvious component visible, which is a discrete component at the end, and looking through the other repairs it doesn't seem to be bonded to the screen like the earpiece.
However, I cannot find a microphone as a replacement component on any of the parts websites. On the full-size Z3 it is part of the main flex, but it's not on the Z3C flex.
Any ideas, folks?
Is dit een goede vraag?
Score 3
1 Opmerking
I've done this a few times, It's actually attached to the "Main Board Flex Cable". It's a fairly tough repair, I'd recommend taking it to a phone shop.
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
For those who still struggle with not working microphone:
Sony Xperia Z3 Compact microfoon vervangen
Was dit antwoord nuttig?
Score 7
I haven't repaired one of these but it looks like it might actually just be attached to the board, like you mention. I have circled on the picture where it looks like it is.
Afbeelding
Score 3
2 opmerkingen:
This video shows one being repaired https://www.youtube.com/watch?v=_ehIFioJ...
door Deel
Wrong video!
door Deel
Voeg je antwoord toe
Steve Brumpton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 7,664
