Ga door naar hoofdinhoud
Reparatiehandleidingen voor veel Nikon spiegelreflexcamera's and compactcamera's.
Nikon D60 Dull image problem
My camera taking dull images even i set maximum resolution. How can i solve this problem? and how to clean my camera lence?
Is dit een goede vraag?
Score 1
1 Opmerking
Tenho nikon nikon d 60 ,quando bato a foto aparece a mensagem de .ERROR PREMIR BOTÃO NOVAMENTE. que será o problema?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
the resolution have no impact on the sharpness of the picture. could you upload a sample image?
are all images "dull"?
cleaning the lens inside or outside??
a dlsr works different than a compact camera - one of the main differences of the picture is the blur - or better - the bokeh (click).
what lens are you using? maybe the lens has a front- or backfocus!
you can use the fosus test chart to find out if your lens has this issue: CLICK
Was dit antwoord nuttig?
Score 2
1 Opmerking:
try a different lens to see if the problem is with the lens or the camera. It is most likely the lens.
Voeg je antwoord toe
manyam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,411
