Ga door naar hoofdinhoud
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Vragen Bekijk alle
Differences between ipad 2 EMC 2415 and ipad 2 EMC 2560
I am replacing the digitizer on my ipad 2. On the tutorials it states there are 4 different models. cdma, gsm, emc2415 and emc, 2560. are all of the digitizers the same for all of these models or does it have to be specific.
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
As far as I know, all iPad 2 digitizers are compatible with one another. I've never had to buy one by model number.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Indeed, when it comes to the front panel of the iPad 2, it's one model fits all.
door
Not true, make sure what chipset you have, either you have the A5 chip or the A5X chip. They are completely different on the inside and different flex cable for all the components including the digitizer and lcd screen, the logic board is different also.
door
Добрый день! Подскажите как я могу определить какая у меня модель именно по EMC. Так как у меня на задней крышке не указан EMC. У меня Ipad2 WiFi на 16 Гб. Можно ответить на email: Maks_rehayhyider@mail.ru Заранее спасибо.
Score 1
Not true! They have different type? Depending on what chip it has. If you have the A5 chip or the A5X chip make sure you know which one you have. A5 and A5X are completely different internal and are not compatible
Score 1
They look exactly the same on the outside but totally different on the inside. That’s what emc are for buy the correct parts. Also if you have the A5 chip or the A5X chip those are completely different internal also.
Score 1
Voeg je antwoord toe
Chris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,340
