Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
3GS Camera On 3G
Can I replace 3Gs camera on the 3G?
Update
I saw lots of 3Gs logic board being sell online, can I replace it on 3G? Now I know camera need to replace, what other part do i need? would the housing fit? would antenna and other port fit? LCD?...etc
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The answer is NO. The connector pins are completely different. Might as well put an original 3G replacement camera.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Sounds like he's trying to do an upgrade though
door
I dunno if he's replacing a broken one, or trying to upgrade, but it just wont fit. The connectors are different.
door
No if you look they have sightly different form factors, I have know idea if you could be successful fiddling around and trying to mod it, but normally it will not fit.
If you need a camera for the 3G you can get it here.
Score 2
Voeg je antwoord toe
MacGeek zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,480
