Ga door naar hoofdinhoud
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
797 Vragen Bekijk alle
How to repair my charging port
When I plug the charger into the Kindle it doesn't connect and my device does not get charged. What can I do?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
This is a pretty common problem with the Kindle Fires. The USB port is poorly designed and comes loose from the circuit board easily. It usually requires the port to be resoldered (or a new port soldered on) in order to fix it. Unless you have pretty good micro soldering skills, you'll need to take it to a repair shop for repair. There are also a number of people who offer a mail in service to repair this (check eBay).
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Vicki Toothaker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 858
