Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Black screen, backlight problem?
I recently dropped my iphone 6 in the sink briefly. It was water damaged as the LCI shows red. I can still charge it; see it in iTune; and if I shine a flashlight on it, I can see the display, but the screen appears black without light.
Does it mean backlight fuse is burned? If so, I don't think I can do it without some real fine tools and micro scope. How much would it cost for the repair shop to fix it?
Thanks.
Is dit een goede vraag?
Score 12
1 Opmerking
Thanks for the answers. The reason why I suspect it being the backlight problem is that I can still see it clearly with a flashlight, and I can gesture and all the things. I thought if there's an LCD issue, I won't even see that.
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Could just be the LCD. Clean the logic board and try another LCD
Was dit antwoord nuttig?
Score 1
If the screen looks very dark but you can see the screen while using a flashlight or looking really closely its more than likely a backlight coil on the logic board so a new LCD/screen wouldn’t fix it. You’d have to take it to a repair shop that specializes in microsoldering and board level repair
Score 1
I would try another screen. I would rule that out before venturing into the backlight repair. Also, look at the connector when you take it apart.
So I could be wrong . But it will be easier if you join fellow detailed pictures . If they are filters that will have a different color .
Voeg je antwoord toe
Joe Zhao zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 28,675
