Ga door naar hoofdinhoud
Instructies, begrijpbaar door een machine, die computerprocessoren aansturen om foto's van katten op het internet te tonen.
209 Vragen Bekijk alle
I accidentally saved an excel sheet over an existing sheet.
Can I recover the original excel sheet?
Is dit een goede vraag?
Score 1
1 Opmerking
Thanks for the tips. However I had not saved it on my time machine yet and I cannot find the excel document in the Library/Microsoft Auto Recovery.
I am a newbie with this so have very little skills. Help has to be spelt out at a basic level please, thank you.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
No.
Here is a sentence to cover the 20 character minimum requirement.
Was dit antwoord nuttig?
Score -1
Het nuttigste antwoord
Not quite true! You'll need to use a file recovery app. To see if you can recover it. But you need to use an external bootable drive with it as you don't want to alter or have the systems OS alter the drive in anyway until you recover the file. You see, the files space as been marked as free space but in fact is still there! But because it's marked as free space any else could use the space so it's important to not use your system until you can recover the file. Hopefully it's not to late.
Score 2
1 Opmerking:
Dan is correct if the original document had been saved at some point. It will also be on your time machine backup.
door
Voeg je antwoord toe
Margaret zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 92
