BMW E38 Rear View Camera installation
Hello
I got the relay switching from bimmernav.com
Same as the one you got in the pictures.
Installed everything as describe:
87= Yellow (connected to ground chassis)
85=Red (connected to ground chassis)
30= Blue (to blue connector pin #17 video module)
86=White (to reverse 12+ wire in the tail light)
The RCA cable to the pins #13 (power input) and #14 (ground input) of the white plug (video module)
However when I put the car in reverse the screen turns black; like if the camera was not connected, but I check the camera with my camera security tester and it is video coming through.
And then when I plug and unplug the connector from the TV video module it works one time and them does not work.
Any ideas what could be the reason?
Best regards
Rey
Is dit een goede vraag?
