Ga door naar hoofdinhoud
Production of the fifth generation 2010 Subaru Legacy began the last week of May 2009 at the Indiana location, and was unveiled at the 2009 New York Auto Show.
3 Vragen Bekijk alle
How to added transmission oil
how to added transmission oil
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
boris, not an easy thing to do. Going to be tough without a lift or a pit. There is a fill plug on the back of the transmission. Remove the plug and put a finger in the hole. If it doesn't come out with fluid on it, it's low. To refill, fill it up in the hole until it comes out. Remember to use CVT fluid only
Was dit antwoord nuttig?
Score 3
It should be up to the bottom of the hole somewhere around 100 degrees Fahrenheit.
Voeg je antwoord toe
boris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 44
Altijd: 17,518
