Ga door naar hoofdinhoud
Hier vind je reparatiehandleidingen en demontage-informatie voor telefoons van alle producenten en fabrikanten, inclusief Apple iPhone en Samsung Galaxy. Kortom, alles wat je nodig hebt om jouw telefoon te repareren.
73637 Vragen Bekijk alle
Vraag afgerond
Are scratches on LCD visible when replacing phone front screen?
I have a screen separating machine and have had a go for the first time. The separating part is quite easy (apart from sometimes cutting through the middle of the LCD *any tips?*).
I have found that after cleaning the lcd screens, there are always some very light scratches left. Are these going to be noticeable after adding the glue and front screen or does it have to be immaculate?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you are applying LOCA, OCA, or some other optically clear glue, the scratches really won't matter. The glue tends to mask most scratches, rough spots and even fingerprints. I used to waste a lot of time getting the LCD's perfect, but after glue application they will look perfect. Unless you didn't clean it all lol.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Wonderful. I was worried that I would have to throw away most of my screens. Time to try gluing them up. Thanks for your help.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 72
