Ga door naar hoofdinhoud
De Sony Xperia Z is een Android-telefoon die in 2013 werd uitgebracht. Het is een van de grootste telefoons uit de Xperia-familie met een 5-inch full HD-scherm. Modelnummers zijn onder andere C6603/C6602.
Adhesive will not stick
I just fixed a Sony Xperia Z and after a little while the adhesive does not want to hold the screen in some places. Do i need to buy a better adhesive?
Is dit een goede vraag?
Score 3
1 Opmerking
I have used kitchen silicone. I have changed this phone display 3 times works every time :)
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
This seems to be a big issue with S5's and Sony Experia's. Best thing to do is to make sure you thoroughly clean frame, apply a plastic adhesive activator and use high quality adhesive's. Also you need to check your frame/chassis for damage, separation, and or whether or not its bent. We've been looking for a supplier for Sony Experia OEM water proof adhesive. If anyone knows where to get it can you please let us know. Thanks
Was dit antwoord nuttig?
Score 1
heat it up with a hair dryer carefully, then put it on its back facing down, put a little weight on the top and leave to set. as mentioned above make sure the bezel is clean from the old adhesive, there is a glue that does help called B7000 we sell this on our site and its a great glue for this type of job, not corrosive like superglue and its flexible at the same time.
1 Opmerking:
Glue B7000 where can i find it, i can't find it on his site
door
Voeg je antwoord toe
heljar97 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 876
