Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung NaviBot SR8855 is een handige autonome stofzuiger van Samsung.
Short shift and turn.
Navibot sr8855 after repair of FET tranzistors for brush have bad mooving - navigation.
From the beginning it worked well and after some time was problem in navigation.
It looks like that: move 20-30cm stop and go back about 3cm, turn 90st. and repeat.
Sometimes work good for 1 minute and then again fail to this state.
I try test mod and all sensors look fine, motors are OK too.
Is dit een goede vraag?
Score 2
1 Opmerking:
I have the same issue. Is there a fix?
door Deel
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Hi,
yes, i found that it was dusturbation in system . I add some capacitors on motor and all is OK
Was dit antwoord nuttig?
Can you describe more precise what did you done?
Could be the aging of the accumulator?
I must replace suction motor and with it start the disturbance of electronics. For this I used capacitors on motor pads. I was 1nF + 100nF + 1uF together. To other motors must be carefull becouse are PWM drivered. There You can use only some smaller - max 100nF capacitors.
1 Opmerking:
Hi
What voltage do you use in capacitors?
door Deel
Can be that the battery started to decay?
It could probably have an effect but it is not a reason.
Voeg je antwoord toe
smsoftware zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 30
Altijd: 2,333
