Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vraag afgerond
vertical dead spot right side of display
I have an iPhone 4S with a dead spot on right side of entire screen, before everybody suggests bad digitizer, I just want to say I tried a few different screens with the same problem I even removed the logic board and put it in a working phone same problem. The problem is at the logic board level and I wanted to see if anybody knows which component is blown so I can replace it, bacause looking under a microscope there isnt anything obvious.
Is dit een goede vraag?
2 opmerkingen
Have you used a meter to check the caps around the touch screen controller? There where I would start to after all the checks you already did.
door
Thanks , That is a good place to start!
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Check to see if there are any pins (female copper type) missing on connection from the lcd or digitizer. I had a similar problem with an iphone 5C and it was because I lost a few copper pieces from the connection.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thanks for the effort Mark, but in the post I already mentioned I tried different screens, this is a logic board level problem.
door
Yeah. I meant on the logic board. There are the copper lining pins on the logic board side too. That's what my problem was.
door
Everything on the logic board is spotless, I guess start checking things with a meter.
door
Yeah hate to say it but you'll have to change the digitizer. I know you don't want to but sometimes it's cheaper to fix the one big problem than look at all the little things it could be. Sorry I can't be of any help, but best of luck though!
1 Opmerking:
please read the full post...
Thank You
door
Have a couple of 4's withte same logic board issue. Did you havr any luck testing caps?
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 275
