Ga door naar hoofdinhoud
The Sony Ericsson W910i is a slide style phone with Walkman software capabilities.
4 Vragen Bekijk alle
screen suddely becomes blank.when I switch off and on it,not working
my phone display screen suddenly becomes blank.when i switch off and on,im not getting the display.it just hangs on
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
if you get a blank screen on a slider phone it is probably cause due to a broken flex ribbon cable connecting the lcd portion to the base of your phone.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
+ agree on that
door
If you get a blank screen, try lighting a torch to the display to check that the images are visible. If are visible, there might be a display illuminance problem. If there is a illuminated blank screen, there is a bad flex ribbon cable connecting the display to the motherboard.
Voeg je antwoord toe
sujitha vankayala zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 1,378
