Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Vragen Bekijk alle
Why is my fan working loudly after a liquid spill?
I picked up the laptop, but due to recently having grown my hair, it was wet and a small amount of water entered the left side, when open in front of you for typing. The screen flickered so i closed the lap top and left it to dry overnight. The next day the computer worked fine, but now the fan makes a loud noise, and it seems a bit slow.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
IF its running slow and fan on high you damaged one of the heat sensors for the macbook. There are a few on the board. It will need an ASD test to tell you which has failed.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks that is very helpful, what is an ASD?
door
Apple Service Diagnosis. You can find the downloads for them by using google search or take it to a local apple store.
door
Voeg je antwoord toe
someveryone zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 3,139
