Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
iPhone died at 30% battery and wont start again?
For a while I have been using "Mobile Power Station" (an external battery charger) with my iPhone 3GS 32GB.
A couple of days ago I used the phone, connected to the mobile power station, just surfing the web. Then, suddenly, the LEDs on the mobile powerstation started flashing. The iPhone LCD flashed one time and then the phone went dead.
And now, it's still dead. I mean really dead, dead, dead. It won't power on, no charge in neither wall or computer.
I tried soft reset (HOME+Power) and connecting to Itunes in DFU-mode, nothing works! :(
It seems to be a hardware error, but what?
Burned circuits?
When I check the liquid submersion indicator in the dock connector it looks red, just like it suffered a water damage. But I know that my phone never suffered a water damage so I suppose the indicator went red just by humidity.
So my question is, what happend to my phone? what do I need to do to repair it?
Thank you!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
surely, the indicators could have had a humidity "damage" - but they should look a little bit pink and not red - but thats not important.
check the board for fluid residue - it's white/greenish stuff on the small parts on the boardif there is any, clean it with isopropyl alcohol (>90%) and a soft paintbrush
it's possible that the battery is totally discharged (means dead) - faulty batteries can show some crappy data - i had phones that went from 100-0% within 5 seconds - i hate to say it, but i would measure the battery with a multimeter
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thank you! I will try this!
door
Battery change solved the problem! =)
door
great that it worked for you ;-)
door
Voeg je antwoord toe
Bengt Barsebaeck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 8,346
