Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
Vraag afgerond
plastic camera bracket removal
How do I get the small plastic camera bracket off my old screen and back on my new screen?
Is dit een goede vraag?
1 Opmerking
Thank you, worked great
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi Jason,
The easiest way to remove the plastic camera bracket, is to get a heat gun or reflow station and go over the front of the screen, this softens the glue and allows you to easily remove the bracket. :-)
Was dit antwoord nuttig?
Score 1
Use hot air (100-200 deg C) for 20-10 seconds, the pry off using fine tweezers or a needle. Be careful as it's springy.
Next to it, there is a tiny square piece of white plastic, make sure to transfer it as well.
Score 1
HEAT works best i usually lightly scrap the glue with a sharp knife
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 75
