Ga door naar hoofdinhoud
Model M8407 / 550 or 667 MHz G4 processor
28 Vragen Bekijk alle
More RAM chip upgrade
Hi. There are 2 RAM chips/cards in my powerbook. I would like to speed things up. What can I change ? One chip says 256MB. The other is Smart SM564328578NW3R. Thanks.
Update
So if I install 2 new chips do I have to run OS9 and firmware to get things going ?
Is dit een goede vraag?
Score 1
1 Opmerking
You shouldn't have to do anything after adding the new RAM. Either 9 or 10 will see it just fine.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You currently have two 256 modules. You do not have to upgrade in pairs so you can remove one and add a 512 MB 3.3V 144 Pin SDRAM SODIMM (PC133) for 768 MB or replace both for 1 GB RAM. Here's the chip you need: http://www.ramdirect.com/vcom/product_in...
Here's a 5400 RPM ATA hard drive that will also give you a boost: [gekoppeld product ontbreekt of is uitgeschakeld: IF107-046]
Was dit antwoord nuttig?
1 Opmerking:
Het nuttigste antwoord
iFixit stocks all the RAM upgrades for your machine as well.
[gekoppeld product ontbreekt of is uitgeschakeld: IF111-022]
As long as iFixit is providing all these resources (funded by parts and tool sales), it's nice to support them by linking to iFixit products when available, instead of off-site.
Score 2
1 Opmerking:
You're correct. My bad. Hopefully they'll soon provide a quality RAM search engine and I'll look to them first. Old habits die slowly and I looked first to where I knew the answer would be and without thinking that iFixit might even carry that RAM I put in a link to someone else. My apologies.
door
The Max RAM for this machine is 1GB, so you can upgrade the RAM, and a faster HDD, thats about all you can do on the hardware side. and im not sure if there are faster than 4200 rpm Pata drives for this machine.
Score 1
1 Opmerking:
Voeg je antwoord toe
Rick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 1,662
