Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Earpiece not working after screen replacement
Hi
I replaced the entire screen on my iPhone 6 after i dropped it and cracked the screen. After finishing the installation, i checked to see if everything works.
The camera and proximity sensor works perfectly but the earpiece doesn't work and whenever i make or receive a call, i have to have it on speakerphone in order to hear the other person.
I don't know if its the actual earpiece that is broken or the flex cable is damaged
I have searched the net for answers but can't find any solutions
Any help would be greatly appreciated
Is dit een goede vraag?
Score 4
1 Opmerking
I believe the earpiece in the replacement screen I received is defective. Is there a way of requesting a replacement?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Here's a few steps you can try to resolve your issue:
- reseat the earpiece so that the contacts line up.
- check for any visual damage to cable or ear piece.
- if this doesn't work, you may have to try and replace either of the parts.
- also, try cleaning contacts with 99.9% isopropyl alcohol, as oils from your fingers can interfere with things.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
thank you for sharing
i have this problem as well although the phone just dropped
can you please share some pics for better understanding as i have never repaired it before
door
Try reseating the earpiece. As there are gold connecter on the proximity flex and gold connectors on the earpiece that need to be lined up.
Score 1
I had this issue today, After changing the screen multiple times trying to figure out why I couldn’t get any sound out of the earpiece- I tried reseating the ear piece and figured I just kept installing it wrong I finally cleaned the connectors and the issue was solved! It’s Amazing how sometimes the simplest things is all that matters!
Voeg je antwoord toe
rkmatthews91 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 17,032
