Ga door naar hoofdinhoud
Een Android-smartphone van Samsung voor de Aziatische markt, bekend onder vele modelnummers en uitgebracht in december 2014. Inclusief de modellen SM-A5000, SM-A5009, SM-A500F, SM-A500F1, SM-A500FQ, SM-A500FU, SM-A500G, SM-A500H, SM-A500HQ, SM-A500K, SM-A500L, SM-A500S, SM-A500YZ, SM-A500Y, SM-A500W.
Why my phone cannot turn off?
y phone was suddenly hung-up when I open my email. I press long press to turn off but it doesn't work. It will not turn-off. How can I solve this one? I try to recharge my phone, it doesn't work also.
Is dit een goede vraag?
Score 21
28 opmerkingen
holding the down volume button and the power button at the same time till the phone vibrates should restart it. if you have it plugged in charging and do this it turns the phone off
door
That was a fantastic clue. works perfect!. Thank You Dude.
door
Wow that really helped me thank you very much
door
worked perfectly. thanks much!!!
door
Amazing advice! Nothing else worked but this did. Thank you :)
door
23 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Press and hold the Volume down and the Power buttons. When the phone reboots, release them.
Regards.
Was dit antwoord nuttig?
Score 33
21 opmerkingen:
Dat was really helpful. ..thanks!
door
its working thank you so much
door
its good idea..... thank u .....
door
good job...... i really like u......
door
it's work... thanks
door
16 commentaren meer tonen
You could remove the battery and this will kill the phone and hope it boots properly when it restarts once you put the battery back in. Hope this helps and good luck
Score 3
2 opmerkingen:
in samsung galaxy a5, you cannot remove the battery since the battery is built in.
door
Many, many thanks
door
unplug Charger before Turning off ,,
it turns off and doesn't reboot ,,
When it's already switched off..you can Plug in the charger and it won't turn on..
Works for me Samsung Galaxy j7 OS 6.0.1
Hello .. I forgot my lock pattern and when I try to hard reset it .. won't let me turn it off .. it wants the lock pattern in order to be turned off but I don't remember the pattern .. so .. no hard reset, no nothing .
1 Opmerking:
Thankyou so much. Totally worked. Only way to power off / shut down your malfunction samsung j 7 prime phone or device. Power & volume - key while its plugged in to charger. Or else it only restarts.
I was so lost, i felt the phone had malfunctions.
Thankyou so much
door
Voeg je antwoord toe
Billy495 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 60,611
