Ga door naar hoofdinhoud
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Vragen Bekijk alle
Vraag afgerond
Do I remove the protective cover removed?
In step 37 B you show that you are raising the red protective cover from the display. Is this required? I am repairing an IPhone 4 CDMA and the red cover is still on there. Please help soon.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes, remove the protective cover on the back of the new LCD assembly.
WARNING: Failure to remove the protective cover from the mirrored back of the display assembly will damage the LCD. There is a thermal pad installed on the iPhone frame that absorbs the heat from the LCD and disperses it though the frame, preventing the LCD from
overheating.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you for the helpful info. I have now replaced two front displays and removed the transparent protective cover.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 77
