Ga door naar hoofdinhoud
De Honda Element was een compacte cross-over SUV gebaseerd op een aangepast CR-V-platform, geproduceerd in East Liberty, Ohio en aangeboden in uitvoeringen met voorwielaandrijving en vierwielaandrijving
How repair engine coils
my car is stalling out Could the 4 engine coils be the problem
Is dit een goede vraag?
Score 1
1 Opmerking
Is your Check Engine Light on? Have you tried to get it scanned for any error codes? Unlikely that all your coils failed at the same time.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Possible, you should get a cheap OBD 2 scan tool to check for mis-fire DTCs in the system. But the easy way to check for misfire codes is to look at the mil light when the car is running. misfire will make the mil light flash.
Was dit antwoord nuttig?
Score 1
By any chance do you drive a standard? Elements, especially those that are sticks, tend to suffer from the exhaust valves going out of spec much sooner than normal. In my experience (the three times this has happened within 130K) is that I would drive semi-aggressively from a cold start. When I came to a stop in the first 5 minutes of driving, the RPM gauge would drop too low and stall. Turning the car back on would keep me moving again for usually the rest of the drive.
You can literally say to the mechanic, "my exhaust valves are out of spec" and they can fix it from there. It's cost me between 150-300 depending on the mechanic doing the work.
Score 1
Voeg je antwoord toe
peder Larsen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 28
Altijd: 712
