Ga door naar hoofdinhoud
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Vragen Bekijk alle
How to fix my display not working correctly?
Hi,
Changing the glass of the ipad mini, when I finished the display won't work correctly. I just displays randoms lines and the bottom of the screen is all black.
I tried cleaning the connectors and pluging it again, but no success. Any ideas ?
here's what is looks like
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
It appears that the LCD is damaged. It is hard not to damage the LCD or digitizer when trying to do a glass only repair. Applying to much pressure, or using the incorrect tools can easily damage the LCD. Your display in the photo signals a cracked or damaged LCD. You will need a new display assembly (digitizer + LCD) to fix your device.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Why is a new digitizer necessary? I have the same issue here, but if the vertical lines signify a damaged LCD, wouldn't that be the only thing to replace? Just trying to save $70 if I don't have to spend it.
door
Yes you would only need an LCD if the digitizer is undamaged.
door
Thank you, appreciate the assist!
door
It looks like you damaged the LCD while replacing the digitizer. What you will need to do is buy a new LCD for the ipad and carefully take the ipad apart again and replacing the lcd with the new one. The glass+digitizer you purchased is still fine and as long as you remove it without damage you can use it again when you install the new lcd.
Score 1
how to repair my ipad mini,i cannot open my itunes only disable never working.
LCD is cracked.involuntarily you have applied too much pressure and LCD is broken. you should replace it.
Voeg je antwoord toe
marcalexandreleger zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 757
