Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Why is my sim card tray not opening
I bought an iphone 6 and inserted my sim, it came up with sim card not inserted but when i put the pin in to get it out to check the tray would not come out i dont know what to do or know of anywhere that would at least try and get it open for me for free or cheap
Is dit een goede vraag?
Score 2
1 Opmerking
Did you remove the tray successfully before? The iPhone sim card try requires a good amount of force to open. What tool is being used to open the tray?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Depending on your cellular provider they usually have sim card poppers to open the sim card tray. It is pretty easy to get open with one of these tools. A cool trick to use to open the sim card tray is using a clothes pin if you don't have the same tool accessible that the cellular company would have. There usually isn't a cost associated unless it ends up being physically damaged. Hope this helps!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Also the Sim Card itself might be stuck on the Sim reader, so be careful when pulling this out just in case you damage the copper readers ! Best case to get this out is to have it opened and push it out from the inside !
door
Voeg je antwoord toe
immrsharper zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 36,779
