Ga door naar hoofdinhoud
Een draagbare e-reader ontwikkeld door Amazon. Reparatie is eenvoudig en vereist alleen wrikwerktuigen en schroevendraaiers.
Kindle Paperwhite Repair code comes on after screen replacement
Can anyone help me with a problem. I replaced my kindle paperwhite screen and now I get the screen saying repair needed. Battery invalid:-22. I am glad the screen works.....
Help??
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Did you find any solution to this?
I have exactly the same problem. I assembled a paperwhite 2nd-gen screen with a paperwhite 1st-gen motherboard and get exactly the same error.
EDIT (typing mistake): it was a 2nd-gen motherboard and a 1st-gen screen
Was dit antwoord nuttig?
2 opmerkingen:
Where did you find a screen of 2nd gen? I need to replace mine.
door
Oh sorry... I mistyped something. What I meant was i assembled a "paperwhite 1st-gen screen and a paperwhite 2nd-gen motherboard"
door
Received a 2nd-gen screen today, still getting repair-message.
5 opmerkingen:
It's not good. Last week I bought this one http://www.ebay.com/itm/311350255136 (2nd gen screen to my 2nd gen motherboard) and I'm waiting to receive it. I hope not to get the same message because I don't know how to deal with it.
door
The message is "Battery invalid:-22.", correct? Did you try to disassemble and connect the battery again? Or a hard reset?
door
That's correct! Yes, I tried both. My current approach is to try it via serial connection. Maybe it's just a software-issue that could be fixed that way. Has your screen arrived yet?
door
Hello, men! So, what with your Kindle now? A you repair it? I have a same problem now.
door
door
Any solutions? I have same problem
I came across a russian site http://kindle.zzweb.ru/paperwhite/repair.... Basicly it sates this:
  1. Connect the Kindle Paperwhite to a computer USB-cable.
  2. Create an empty file in the root directory DO_FACTORY_RESTORE.
  3. Safely disconnect the reader from your computer.
  4. Reboot your device by holding the power button.
I did this and my kindle paperwhite did a factory reset and I was able to use it again. I had previously tried to format the drive and place a firmware update on the drive so I do not know if this will remove your books. Please try and back up your books if you can before you do this.
Hope this helps others.
Voeg je antwoord toe
sdinovitz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 3,195
