Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
How do I bypass the code of a water damaged iPhone 5?
I Have a customers IPhone 5 that is watered damaged. I have dried and brushed the IPhone with alcohol. The phone works but the screen will not turn on. I can hear seri and the vibrator. I just need to extract the info. How can I do the without the screen working?
Thank You
Is dit een goede vraag?
Score -1
1 Opmerking:
did you check the components around the LCD connector?
door
Voeg een opmerking toe
1 Antwoord
If you're hearing Siri, cleaned the motherboard etc. with alcohol, there's just the contaminated LCD + Touchscreen, you need a new one.turn off your iPhone with replacing the batterie and than get start changing the screen
Was dit antwoord nuttig?
Voeg je antwoord toe
chapsh2o zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 117
