Washer will not drain after wash cycle?
Tried Spin cycle several times.
Is dit een goede vraag?
Ken, if it sits there waiting to drain, check to see if it is absolutely silent or if you can hear a hum. If it hums it could be something stuck in the drain pump or you may have a defective drain pump. Check on here how to replace the pump. If it does not hum then the problem is more likely the lid switch.
Was dit antwoord nuttig?
Good answer!
You saved my day!
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 9
Altijd: 2,423
