Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De ZTE Boost MAX N9520 beschikt over een 5,7-inch HD IPS-scherm met 4G LTE en Android 4.1.
How to fix my power button?
My power button is not turning my phone off, it is only locking the phone. How can I fix this problem asap?
Is dit een goede vraag?
Score 11
3 opmerkingen:
i have this same issue except before my phone died it wasn't locking the screen either.
door Deel
I tried to put my phone into a virtual reality headset and my power button was pushed all the way due to my device being to large for the headset. I am trying to find out how do i manually fix my problem.
door Deel
I can't get my ZTE MAX to turn back on. I don't usually let it get so low that it just shuts off but, that's what I did. I charged it overnight & now, it won't come back on! HELP!
door Deel
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Hello jacquettasurles,
According to your sounds it could be power switch also software related fault, if power switch not works properly this kind cases comes.
[http://Here |ZTE Boost MAX N9520 schermmodule vervangen] is teardown guide and you can replace the power key (Step 4)
Was dit antwoord nuttig?
Can somebody help me I need to know how to cut on and off my ZTE phone but it takes to long to cut on and off I tried reset my phone but that didn't work ethier
My volume. Button is not working like when you try to turn the volume down and my power button won't turn off
I need help please
My power button well not lock my phone or turn it off what do I do?????? And it's bran new I just bought it a week ago and I have never dropped it or anything it's a ZTE MAX somebody please help..
Voeg je antwoord toe
jacquettasurles zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 7,647
