Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor een breed scala aan recreatievoertuigen.
need repair advice on rv
I have a 77 chevy itasca c25c rv with small block 350. And it has a. wiring nightmare. And cant find any books on how to fix it. My accessory batterys arent charging and not sure how to find the problem. Next my stove/oven last time i used them they both worked. And now they wont light at all. And my tanks are full. I have a magic chef 4 burner stove model j594060.then my fridge hasnt worked at all since i bought it. And no clue where to start.its a norcold model 876eo2 . The heater works fine. But i have a leak coming from my hot water heater. Not sure from where. Model
Bowen g6a2 . Can anyone please help. I also have no working dash gadges. Im new to this and not enough money to take to repair shop to have them do it. So its time for me to learn. And no one has repair books for a rv this old. Help!!!!!!!
Is dit een goede vraag?
1 Opmerking
patricia wisham, sounds like you have your hands full. Did all those things fail at the same time or did they fail at separate times? Without trying to be insulting, what's your skill level like? Handy with a multimeter and some electrical tools?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
patricia wisham, start with the main wiring on your control center. I attached the chassis wiring diagram. Not sure if you can make it out. It is a scan from the original wiring manual.
Afbeelding
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Yes this is gonna be very helpful. Thank u very much. And I'm a little handy with volt meter and tools. But willing to learn and get it done.
door
let us know what you find out and if you need any more help.
door
The wiring diagram was just what I was looking for. If you possibly have any other manuals on this would be ever so helpful and grateful. I've got my work cut out for me.any advice or suggestions on how to do water damage inspections and repair? Please I need all the help I can get.
door
If the accessory battery is not charging while hooked up to shore power, take a multimeter ad check the voltage coming out of the DC ports checking from + to - (or black to red) it should be around 14vDC. If its less, the converter needs replaced.
Voeg je antwoord toe
patricia wisham zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 856
