Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Vragen Bekijk alle
Vraag afgerond
Can Sim reader be fixed
I have an iPhone 4 that was ran over I replaced everything on it screen lcd battery homebutton and speaker wifi antenna and cellular antenna everything was done correctly but still can't read sim says searching or no sim can the sim reader be damaged and if so replaced?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It certainly can be fixed. But it would takes a look under a microscope to identify what was damaged. A small IC oder a track. It just needs to be resoldered but you need specail equipment for microsoldering.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
You know where I somewhere I can send it to be done for something like that?
door
Het nuttigste antwoord
Yes
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 104
