Ga door naar hoofdinhoud
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
58 Vragen Bekijk alle
Why does the engine warning light remain on
The engine warning light remains on.
Is dit een goede vraag?
Score 1
1 Opmerking
it's the egr valve most likely. common ford problem
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The engine light is telling you theres something wrong with your car and that you need to give it some attention . You can start by getting a OBDll reader and getting the code to tell you just what you need to fix. Once you have the code and have fixed the problem you can delete the code and the light will be out
Was dit antwoord nuttig?
Score 1
You do not give us a lot to go on. I suggest that you get the OBD scanned at places like Autozone or others and see what code it returns. there are hundreds of reasons why the light could be on.
Replace the engine if it's bad
Voeg je antwoord toe
dbryantnc zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 515
