Ga door naar hoofdinhoud
De Samsung Galaxy Note II is een smartphone die bekend staat om zijn combinatie van een groot beeldscherm en software die geoptimaliseerd is voor een geïntegreerde, in het toestel opbergbare stylus.
Cannot connect to wifi
my phone's wifi is not working
my wifi signal strength is very strong but it's not able to connect
the status shows obtaining IP address
and after a while it tells network disabled. Poor connection
I checked on the net they say it's because of the update of the phone original version 4.1.1 to 4.1.2 jelly bean, the update is causing the phone wifi connection go crazy
I checked for the solution, in many forums they showed to change the IP settings from DHCP to Static which I did and then after entering the wifi password there is no save option
I tried this way too..the link is below
https://www.youtube.com/watch?v=zyO66lqT...
the first way is dialing *#0011# but it's still not connecting
the second way was too confusing so I didn't try
I checked it online and I guess this problem does not only happen in note 2 but almost all the android phones
Is dit een goede vraag?
Score 5
1 Opmerking
I have the same problem suddenly in a day. I reset my phone once and I downloaded the wifi fixer, diff., versions, it just does not work.
door
Voeg een opmerking toe
6 Antwoorden
Filteren op:
Het nuttigste antwoord
my phone is not connecting to wifi and bluetooth
Was dit antwoord nuttig?
Score 1
Hi Smriti
Have you thought about the wifi antenna being faulty and to try a replacement?
2nd Rssi is not available
disconnect then put your password back in. that what i did.
I can not connect wifi in my mobile
I would recommend replacing the WiFi antenna.
Voeg je antwoord toe
Smriti Sharma zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 25,865
