Ga door naar hoofdinhoud
Informatie over plastic, inclusief reparatie, modificatie, en restauratietechnieken tegen vergeling.
9 Vragen Bekijk alle
How do you take off paint scratches from a plastic surface?
I just wanted to ask how I would take off some white wall scratches off of my plastic vacuum ?
is there any type of liquid you can find at home that takes away that stuff?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
First you'll want to try one of the Citrus oil cleaners like: Goo Gone. Just test it out some where it won't show first. They do a good job on label adhesives as well. I would then try using a polishing powder like: Bon Ami with a damp cloth as it won't scratch. After either you do want to put on a protectant like: Armor All.
Was dit antwoord nuttig?
Score 5
1 Opmerking:
thanks so much for the help I really appreciate it :)
door
There are a variety of plastic cleaners, polishes, and compounds that work well for this. I have found Novus Plastic Polish Kit to work wonders; Meguiars has variety of products based on color and type of plastics; Mothers also has a polish for scratches.
Score 1
First step is to remove the wall paint without Scratching the plastic surface. Dry wall paint gets soft with - water! No rocket science needed. If possible submerge it into water with a dash of dish cleaner for some minutes. Than take a wooden spatula or fingernails to scrub it from the surface. Any scratches you can polish with toothpaste or grease based polish like mentionned before.
Voeg je antwoord toe
yataouss zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 69
Altijd: 7,353
