Ga door naar hoofdinhoud
Informatie over plastic, inclusief reparatie, modificatie, en restauratietechnieken tegen vergeling.
How do you take off paint scratches from a plastic surface?
I just wanted to ask how I would take off some white wall scratches off of my plastic vacuum ?
is there any type of liquid you can find at home that takes away that stuff?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
First you'll want to try one of the Citrus oil cleaners like: Goo Gone. Just test it out some where it won't show first. They do a good job on label adhesives as well. I would then try using a polishing powder like: Bon Ami with a damp cloth as it won't scratch. After either you do want to put on a protectant like: Armor All.
Was dit antwoord nuttig?
Score 5
1 Opmerking:
thanks so much for the help I really appreciate it :)
door
There are a variety of plastic cleaners, polishes, and compounds that work well for this. I have found Novus Plastic Polish Kit to work wonders; Meguiars has variety of products based on color and type of plastics; Mothers also has a polish for scratches.
Score 1
First step is to remove the wall paint without Scratching the plastic surface. Dry wall paint gets soft with - water! No rocket science needed. If possible submerge it into water with a dash of dish cleaner for some minutes. Than take a wooden spatula or fingernails to scrub it from the surface. Any scratches you can polish with toothpaste or grease based polish like mentionned before.
Voeg je antwoord toe
[deleted] zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 91
Altijd: 7,917
