brake warning light stays on
my brake warning light stays on cleaned terminals
Is dit een goede vraag?
Check that your brake fluid reservoir is full of fluid! My clutch was leaking and while the reservoir is designed to not allow the clutch to draw below the line necessary for the proper operation of the brake, the brake light was still on intermittently. It is a float sensor that checks the fluid, make sure it is not stuck. WillieP is also right in checking the sensor for the parking brake, it is simple wire that when grounded will turn the light on.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 3,378
Thanks for the info! I pulled er brake up to clean the “boot” the day before I found the dashboard brake light on and hoped that was the problem...so I pulled it up and released it 3/4 times. And today the light was off! Will check in w/mechanic anyway...
door victoriab2839
